My 1991 Accord dyno results
    Ignore the Lambda measurements - that is for air-fuel and they were not able to put their wideband O2 on my car.
    Here's the link to the video of the dyno run. I am the one holding the camera. http://www.youtube.com/watch?v=067cqe6dCPA
    My little girl
    1991 CB7 Accord EX
    F22A4 with P12 ECU on the stock four-speed automatic
    K&N E-0774 air filter in place of airbox
    NGK Iridium IX spark plugs
    Sony CDX GT640UI head unit
    6.5" 2-way Alpine Type S up front
    6x9's 3-way Alpine Type S in back
    MTX Terminator 600W peak 50W RMS 4-channel amp
    nice man. ima dyno my car next month to see what numbers im pushing. 108 is kinda low but then again your auto. but nice man.
    what mods do you have?
      Mods are K&N E-0774 filter in place of the airbox, a P12 ECU, and NGK Iridium IX spark plugs
      My little girl
      1991 CB7 Accord EX
        nice mostly stock dyno...love seeing these.
        ____
          get a SRI or CAI and get another dyno run and see what gains it give you
            i'd love to see a dyno on a full header-back 2.25" exhaust and intake.
            _____________________________________________
            2 year ASE Certification/Auto Technician Degree completed
              is this whp?
                being a dynojet i'd assume so.
                Cars:
                91 Accord LX Sedan (sold)
                98 Accord LX Sedan
                95 Eagle Talon TSI AWD (E3 16G, PTE 780cc, Godspeed FMIC)
                  Nice...
                  1990 Accord LX Sedan~Sold
                  1993 Accord EX Sedan~Sold
                  1995 Suzuki GSX-R 750~Totaled
                    that seems kind of low given the mods you've done. have you done a tune up lately?
                    They rise their wooden pints and they yoik and sing
                    And they fight and dance 'till the morning
                    Dont forget my MRT for my 1992 Honda Accord LX
                    Everything in Japan is made with carbon fiber and used panties.
                      he only has a K&N air filter on his OEM intake and the p12 ECU. thats whp. the F22a1 only comes with 125hp to the crank stock.
                        Thats very decent numbers for stock cb7 auto, good dyno run.
                        cb007
                        first cb wit full LED taillight retrofit
                          You can hear AND see where the 3rd gear does it's little trick where people think it's an extra gear. Sounds great too man. This makes me think back to the time my car only had a short-ram.
                          98' Mustang 3V Swap
                          11' VW CC R36
                            That ain't a trick - that's the torque converter lockup clutch engaging. It supposedly engages twice on these cars, as the automatics are labelled "four channel, two lockup" automatic transmissions, which may mean four gears with the lockup clutch engaging twice. Also, if I read the transmission design info correctly on the internet, it appears as if the automatics in these CB7s are basically manual transmissions with a torque converter in place of the clutch and a stator plate is used to shift the gears - these automatics are not planetary gearsets like the rest of them are. These ones are designed like a manual with three shafts that mount four forward gears and a single reverse gear, using a stator plate powered by hydraulic pressure to shift gears - the first shaft is the drive shaft, which is powered by the crankshaft through the torque converter and has a single gear on it that powers all the other gears. The two remaining shafts both mount the four forward and one reverse gears and both are connected to a limited-slip differential that powers both front wheels at the same time. That also explains why these cars are able to hold their position on slight inclines with no brake pressure.
                            My little girl
                            1991 CB7 Accord EX
                              i vote sticky this in the beginner section if only we can get more post up
