What is the quietest performance exhaust/muffler?
    i was looking on ebay for the obx twinloop, but nothing showed up. only some other even more generic company.
    i really need to get some sort of exhaust. the top end on this car is struggling a little cause its being choked by a 2.25 piping and a stock muffler.
    i know theres a point where youre not going to get high flow without being louder, but i would like to keep it as quiet as possible... at least when im just cruising.
    and setups like the ws1/2, greddy, etc is out of the question, cause i also want a small muffler tip. 3" max.
    If you're talking about the TL, Comptech is back in business
    Finally Up and Running. Numbers to Follow. Check my MR
      Complete performance and quiet don't really mix.
      Quiet exhaust are baffled/chambered. Chambers/baffles create exhaust restrictions. Exhaust restrictions limit power.
        oem
          Im not sure how easy it is to get to to work....but try looking into the new civic sis exhaust....the tip isnt overly large and it sounds nice but no loud at all.....I cant remember how big of piping the si has though
          Burrito Bandidos: It will change your fuckin life
            i still have my twinloop
              yah i am having the same problem,
              i got quoted
              108.25 for a 2000 civic muffler and assembly,
              i think ill be picking that up soon.
                its a stock muffler thats rated for more power,
                win , WIN
                  you didnt have an obx did you... didnt you have the "other"?
                    oem lol
                      yea but if you want to come pick it up, it's your's. i modified the tip but still have the original 3".
                        I posted this some time ago
                        Originally posted by rexload View Post
                        you can make a great sounding muffler for about 50bucks
                        -get a chambered Thrush muffler from summitracing.com
                        I believe they are called "Dynomax Thrush Welded Mufflers" and cost around $30
                        Just make sure you do not get a "Thrush Turbo Muffler" and make sure it matches your exhaust piping size. You probably wanna get the 2.25" - it will be actually bigger, 2.25" will be the inside diameter.
                        -go to any auto parts store and get some exhaust pipe "reducers"
                        you will need one that is 2.25" outer diameter and 2.00" on the other end. then get a ~2.00" to ~1.5" reducer, then just get some 1.5" or 1.25" steel pipe
                        -have a muffler shop install the Thrush muffler on your car
                        and also have them weld the reducers and the 1.5" pipe together for you. so you will have a pipe that is 2.25" outer diameter on one end, then gets smaller and smaller and ends up being ~1.5" on the other end.
                        have the muffler shop make it 12" long and then you can always shorten it
                        -now just take that "silencer pipe" you made and insert it into the outlet of the muffler. it should go through one chamber of the muffler and end in the other chamber. it will not fall out because your muffler is 2.25" inner diameter and your "silencer pipe" is 2.25" outer diameter on one end. it is also not visible. you can drill a hole in the muffler outlet and put a little screw there to ensure that it doesn't move around.
                        it will sound great. slightly louder than stock but MUCH MUCH quieter than any straight-through or twin-loop
                          just get a turbo muffler.
                          spin city
                            when i first got on cb7tuner, there was a thread going around talking about gutting the RSX (type-S?) muffler and re-welding it up. not sure if thats something you'll be looking into.
                              apexi w/s hands down
