Head Gasket ??
    Head Gasket ??
    I am using an H23 head and block and need to go oversized. There are no company's that makes a oversized HG for this block (cometic couldn't do a custom either). So is it possible to use the H22 one? Everything that I have searched shows for a H22 head going on a H23 block and that it leaks near the cam seals.
    try bisimoto, dey did burlees head gasket with oem honda gasket too.
      talked to bisi about a few things. He doesn't have anything for the H23.
        how much oversize? if you are going .020 over then it will be fine.
          going 88mm or .40 over.
            Contact golded eagle, they can bore any headgasket for you.
            member ride thread
            DIVULGE MOTORSPORTS
              talked to them too and they can't do it either. Really need to know if I can run the H22 one on this setup.
                Why not use an oversized f22a gasket? i know bisi has those for sure.
                member ride thread
                DIVULGE MOTORSPORTS
                  f22a HG on a full h23 block/head? i dont think it would work.
                  i talked to wicked and said you should be ok with oem h23
                    OEM hg's are only .5mm bigger than the bore. This guy is going to 88, from the stock 87.
                    Depending on the piston type, he might hit.
                      Thanks G, going to try the stock h23 one but still very worried about the fit. So I guess no one knows for sure about the H22 one. Pretty sure the F22 won't work but has anyone confirmed it.
