I would like to go with over sized valves in my G22 build , but I'm not sure if they will fit with the hybrid engine setup . I have Bisimoto 86mm 8.2 to 1 compression pistons and Skunk2 stage 2 turbo cams and I'm considering 36mm intake and 31mm exhaust valves . The pistons have relief cuts for the valves and they are close to the edge of the piston . The Skunk 2 cams have quiet a bit more lift than the factory H22 cams and I don't know how to figure out if there is enough clearance for the bigger valves/higher lift cam . I can't find anyone who has used Skunk2 cams in a G22 or over sized valves .
Over sized Valves in a G22
