how different is the 4th gen exhaust system from the 5th gen??? Will the 5th gen exhaust fit on a cb with out modification??? aftermarket
exhaust question???
Originally posted by ChampCoupe View Posthow different is the 4th gen exhaust system from the 5th gen??? Will the 5th gen exhaust fit on a cb with out modification??? aftermarket93 accord Black 10th Anniversary (REBUILD)
http://www.cb7tuner.com/vbb/showthread.php?t=125009
1992 Accord Lx Frost White - SOLD
1993 Accord Se Coupe - Totaled
1992 Accord Ex Sedan 5 speed - SOLD
1992 Accord Lx Coupe - SOLD
1990 Accord Ex Sedan 5 Speed - Daily Driver
1993 Accord 10th Anniversary - STOLEN (REBUILD)
Originally posted by JoshM View PostNo, one of the bends toward the back is different. It doesn't fit in the CB's exhaust tunnel.93 accord Black 10th Anniversary (REBUILD)
Edit, there's actually several differences:
4th Gen:
5th Gen:
MR:http://www.cb7tuner.com/vbb/showthread.php?t=150506
CHAMPCOUPE IS BACK !!!!
I have a OE 5th gen ex cat back on my cb. I cut all the flanges and had the pipes re-welded. The 5th gen exhaust is a little bit longer than ours so you have to take of a little pipe. But pretty much the same shape. It won't bolt up 100% but you can make it work easy.R.I.P Rex 10/10/97-08/06/09
There aren’t enough words in this world to say how much you will be missed. love you buddy!
Originally posted by flcb7 View PostI have a OE 5th gen ex cat back on my cb. I cut all the flanges and had the pipes re-welded. The 5th gen exhaust is a little bit longer than ours so you have to take of a little pipe. But pretty much the same shape. It won't bolt up 100% but you can make it work easy.
