abs codes
    abs codes
    does anyone know what are the abs codes cuz i got some
    Sure le tme go find my oem manual
      It would have helped if you told me the code so i dont have to type all of this but i gusse i can use it in the future and make a dyi out of it
      Long blink = 10 short blink = 1
      Code 1 - Problematic componet; Other Componet
      Code 10 - Pump motor Over-Run; Pressure switch
      Code 12 - Pump motor circuit problem; Motor relay unit fuse Motor fuse
      Code 13 - High pressure leakage; Solenoid
      Code 14 - Pressure switch
      Code 18 - Accumulator gas leakage
      Code 21 - Parking brake switch-related problem; Brake fluid level switch, BRAKE light
      Code 31 - Front right Pulser
      Code 32 - Front left Pulser
      Code 34 - Rear right and left Pulser
      Code 41 - Front right speed sensor
      Code 42 - Front left speed sensor
      Code 44 - Rear right speed sensor
      Code 48 - Rear left speed sensor
      Code 50 - Rear left and right speed sensors; Modulator
      Code 54 - Rear right speed sensor; Modulator
      Code 58 - Rear left speed sensor; Modulator
      Code 60 - Fail safe relay ( short ) Front or rear fail-safe relay
      Code 61 - Fail safe relay ( short ) Front fail-safe relay
      Code 64 - Fail safe relay ( short ) Rear fail-safe relay
      Code 71 - Solenoid related problem ( open ) Front right; ABS B3 fuse
      Code 72 - Solenoid related problem ( open ) Front left; ABS B1 fuse, Front fail-safe relay
      Code 74 - Solenoid related problem ( open ) Rear left and right right; Rear fail-safe relay
