Apexi s-afc
    Apexi s-afc
    Would installing one of these do me any good? I have a 91 ex with the f22a4 motor. Currently the only thing i've done is added a short ram intake. Future plans include a cat back and possible high-flow cat converter. I also plan on doing the header shortly after, but have read since the EX came with a 4-1, I would moslty only gain a little weight loss and better looks...is that true? Would modifying the a/f mixture help me gain a few ponies or is the hassle of install/tuning/price not even worth the time. All advice is appreciated.
    91 EX 4 door Seattle Silver
    f22a4
    Short Ram
    axle back
    sittin on 17" enduros wrapped with nankang ns-1's
    more to come...
    No I really dont think so atleast not in this case unless you have a turbo or some sort of shit in that car I see alotta people use that for cars with a turbo on it I dont really know much about it .
      Use will need bigger fuel injector like DSM 450cc to use the S-AFC hack( accord stock is 240cc). Unless you have a built up engine (rod, piston, camshalf..) or Turbo your waisting money on the S-AFC, it cost about $300 and are a pain to tune. You have to go to a shop with a wide band Dyno to get it tune. and it has to be re-tune when you install new part like bigger fuel pump, fuel presure regulator....
      If you have the money you can buy it and set it to monitor mode. it will display digital or analog of Thottle %, RPM, airflow, battery voltage. Then when you built up your engine or Turbo then you can get it tune correctly, if it set wrong you get check engine light, car will feel slower and is not responsive, worst low gas millage.
      cat back and header are easy bolt on power so u should do that next.
      90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
      < 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
        For F22A stock engine..
        I would recommend turbo timer..
        Why? After turning off your engine..
        turbo timer let the engine run for 30sec to 1min
        to cool down the engine..
        Good for your car!!
        1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
        2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
        3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
        4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
        5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
          Re: Apexi s-afc
          Do you meatheads see the word TURBO anywhere in his post???
          If you only have an intake then I'd hold off until you had more mods... you can probably pick up some mild gains w/ the SAFC on any car w/ some dyno tuning time...but basically the more mods you have before getting the SAFC the more power you will pick up from tuning the a/f...
          Oh and the EX came with a tubular 4-2-1 manifold...not 4-1...most aftermarket headers will give you a few hp more than the EX tubular manifold...but it's up to you... it will become a bottleneck if you go beyond the basic bolt on stage...
          RIP Lifsatrip7
            man, thanks for the info, thats what i was waiting on
            thanks again!!!
            f22a4
            Short Ram
            axle back
            more to come...
              thanks again!!!
              anytime dood...
              glad I could help...
              I hope you were talking to me...lol.
              RIP Lifsatrip7
                i was
                f22a4
                Short Ram
                axle back
                more to come...
