Oening up the IM
    Oening up the IM
    Hey fellow tuner's
    I want to know any gains of opening the IM ports. Meaning ridding 8 ports and opening them up to 4 port IM sort of like a poor man Euro -r intake mode without cutting deep into the runners. I know top end will be improved
    but would smog be affected as well?
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
    depends on what type of smog...two speed idle or dyno smog?
    it may affect a dyno smog because they load the motor up pretty well and if it bogs the shit out of it, then it will affect emissions.
    I <3 G60.
      2 speed idle smog
      NEW CB
      new
        What about the low end power? What happens to that? Sorry to thread jack!
        Members Ride sold...
        I'm back...... with a coupe. oh boy here we go.
          it'll kill lowend a little bit. gutting the iab's out is purely for top end.
          I <3 G60.
            Well what I had in mind was to keep the IAB plate stock for when I go smog my car the remove the iab plate and mount plenum to runner's.
            I feel that with the unmodded IAB plate that should be okay smog
            Wed3k chime in anytime
            NEW CB
            new
              that sounds like a good route, when is smog due?
              I <3 G60.
                Not sure at the moment car is still down
                NEW CB
                new
                  what can you do to the intake to bring the lowend out? i have an H23 IM ... sorry to thread jack.
                    more compression I'm guessing. If I'm right just buy a thinner headgasket, maybe others will chime in, lowend won't suffer that much from what I read
                    NEW CB
                    new
                      just to the intake? id probably keep it stock, a stock h23 will work well and even extend your rpms to 6k
                      I <3 G60.
                        i got a stock h23im with double stacked iab's and it port-matched to my 68mm throttle body and mine has phenominal bottom end and it doesnt choke out past 6k. i used to shift at 7200rpm before the rebuild without any sign of intake restriction.
