So my car isnt running and someone said it is my dizzy. When I had my swap done, they changed it over to an internal coil. What Im wondering is what Dizzy should I be buying that is internal coil and will work with a obd1 h22a?
H22a Distributor issue
The JDM H22a is internal coil while US H22's are external I beleive. Those dizzy's can be complicated sometimes to convert to whatever you want them to. Your best bet is to either get an external coil H22a or H23a1 dizzy and with a little converting, it will work great and probably have better spark.
And that brings on my next question, if I was to switch it over to external, what would have to be done?Originally posted by Shag Wagon View PostThe JDM H22a is internal coil while US H22's are external I beleive. Those dizzy's can be complicated sometimes to convert to whatever you want them to. Your best bet is to either get an external coil H22a or H23a1 dizzy and with a little converting, it will work great and probably have better spark.
I just wanna know if I go to discount auto or autozone what dizzy can I ask for? I am not a mechanic in any way so I really need as much advice as possible. Someone told me they think my ignition control mod was bad in my dizzy.....if so, can I buy just that part? And if so, being it is a JDM h22, what part do I order? SOrry I am so clueless....trying to learn
I think the 90-91s are internal coil, I heard something about a 99-01 Civic Si dizzy working as well. I'd take yours in and match them up if you can take apart the cap/rotor and see if it all matches.Originally posted by Sway View PostI just wanna know if I go to discount auto or autozone what dizzy can I ask for? I am not a mechanic in any way so I really need as much advice as possible. Someone told me they think my ignition control mod was bad in my dizzy.....if so, can I buy just that part? And if so, being it is a JDM h22, what part do I order? SOrry I am so clueless....trying to learn
So as long as I get an OBD1 Vtec Dizzy I should be good?Originally posted by jdmjunky View Postwith my experience with honda dizzy's i know that just about any dizzy will work with any motor as long as it is the same obd design and if your motor is v-tec the dizzy has to match and vice versa.
