I have a turbo F22 and the rear engine mount is the automatic version with vacuum. (I did a manual swap in the past and I kept the auto rear engine mount cause I do not had the manual engine mount in my possession.)
with the turbo setup and civic ECU I don't think this vacuum engine mount work anymore and I want to swap the engine mount for the manual version.
so i'm wondering which mount to choose between the #3 and #5 on this picture:
Also, the hole pattern of these 2 mount do not seem to be the same.
is the differents holes patterns are already done on the sub frame?
Also I want to fill the mounts with polyurethane.
I already have the front mount filled with windshield urethane. I want to prevent the engine moving under acceleration but i don't want too much vibration because it's a daily driver.
Is filling all the mounts will cause too much vibration or is it better to just fill only the front and the rear mounts?
thanks
is the differents holes patterns are already done on the sub frame?Also I want to fill the mounts with polyurethane.
thanks
how do i fix this!!! TIA
