rev problems 91
    rev problems 91
    havin mad issues with 91 exr it's an F22A? can't read all the numbers well here it is ...starts good runs good when at speed slowly...WOT wide open at 3500-4000rpm it stats bouncin any ideas first import
    so what's the problem?
    you really need more information, like the actual engine code, symptoms, modifications to the engine. without these we can help you about as much as you can do yourself.
      might it be the ecu i heard something about a rev limiter being on the car?
        no mods yet all stock 320km on motor and how do i get the engine codes?
          first off, only check for codes if the CEL is on. the rev limiter is a little past where redline starts. Please elaborate on your problem, does it happen often, every time, is it related to speed, throttle position,etc. are you auto or 5 speed. is your car maintained regularly?
            auto.stock car was not running when bought replaced dist. and coil wires pugs fuel filter. now the rev problemhappens when i punch it it bounces off 4000rpm ..when i'm driveing normal getting up to speed moderatly the car if fine drive fine when desired speed is reachedit's when i punch it it will not get and higher rpm's then 4000 will not go past even in neutral park in gear?
              torque converter?
              If not, than my next guess would be that the ECU is in limp mode...does limp mode throw a code?
              -Methael Ravenwing
              SOHC Non-VTEC F-series for life
              "It is the fools prerogative to utter truths that no one else will speak."
              -Morpheus (The Sandman)
                limp mode=CELs so is your little orange engine light on? because it sounds like a cel isnt allowing you to go any higher.
                  the cel does come on and what is limp mode and the ecu is the computer?
                    i remember that in a video i saw a accord shifting at 5k and wouldn`t go any higher, the guy said it wasn`t throwing CELs but he couldn`t rev past 5k in gear........
                    GET A TUNING QUOTE FROM ME AZ PEOPLE
                    "TÜNE.FREE Engine Management!"
                    ...::SHAWNEE::...
                      my diagnosis is limp mode or something in the wiring harness....
                      ...::SHAWNEE::...
                        is there a tool to use to find uot and diapnose the problem if so what is it and where to get it
