Intake Manifold Port Questions
    I'm porting an H manifold. Couple of q's. suggestions would be helpful if you have more info on porting intake manifolds. This is going to be an N/A build... mid 11 compression, bisi headers, head already ported and upgraded with supertech valvetrain, 70mm TB.
    Just behind the injector hole, it curves down slightly. Should I port it enough to straighten out the curve a little? Circled in red. Of course, I wouldn't port enough to touch the hole, just close.
    How about the plenum... Cutting out the middle port section and have it completely open.
    Runner entry. Circled in Red. What you think about sharpening the bridges? ((If I cut the bridges from the plenum out)) Instead of the incoming air hitting the flat surface, it would be cut by the sharpened edges. What you think?
    Butterfly plate. I would like to keep it in there. How about sharpening the bridges of that instead of the bridges of the runners?
    I have the blacktrax thermo spacer as well, so I guess I have something else to play with.
    Hey guys
      Is this fora h or f block. Need to know before I give an answer
      NEW CB
      old Darkcloud : 1990 Accord EX MRT
      new
      DARKCLOUD : 90 ACCORD EX MRT
        This is for an H block.
          you're completely taking a shot in the dark with shit like this without tests that arent' worth doing unless you're seriously into racing.
          i'd either "clean it up", match it to the gasket or less or i'd leave it alone.
          i remember doing this once and ONLY this on an f22 and losing 2hp over the course of 3 runs in identical conditions.
            http://www.cb7tuner.com/vbb/showthre...=95154&page=12
            Read the bottom of page 12 and through page 13. Especially pay attention to the first post on page 13.
              Here is one I did, I never dynoed it though
                Thanks for the replies gentlemen. The pictures and threads were a good read. Right now I'm just cleaning it up. I want to keep the iab in place.
                I'm thinking of opening up the plenum like this.
                Cutting the runner like this.
                On the iab plate, I would like to blend the bridges round. So the air has an easier transition into the runners. Not hitting the flat spots on the bridges.
                Or just cleaning up the casting marks and leaving it alone lol
                Thanks again for your input.
