dual runner problem?
    ok i did the a6 manifold swap months ago with no problems. the black box that controls the butterfly valve i had wired the black wire to a engine ground and the red into the inside off of a 12v switch. it was working fine off the switch. well now i just got my car back a week ago and the butterfly valve doesn't work im guessing the black box doen't work right seein how everythink is hooked up right. is there another way to hook up the valve to make it stay shut then open up aroud 4k rpm's with out the black box?
    SCREW THE BLACK BOX.....................just hook up a vaccum line from the butterfly valve to a open vaccum port on the manifold and then ur set.
      will the dual runner open up with it hooked up like that? if so about when will it open?
        Originally posted by fizzbob7
        about 500rpm sooner....not a noticeable difference......there's a discussion about this on some other thread
        wont that lower the hp for that 500 rpms?
        Dynamic racing
        Look out for 4 point cb7 strut bars for dohc!!!
        bleh... i just put like 5 ounces of vodka in a 12 oz cup of mango iced tea...
          it does work its the same if the black box was in the middle of the vaccum hose but ur takin it out. its done manually. which i think that it is better. i feel it around 4500 or soo. when i had my SOHC in it felt it kick in. but know i have the DOHC (h23) i feel as well
            yep, 1-3hp....a 20mph headwind will rob you of more than that
            oooooo ok
            Dynamic racing
