OK guys, this might be a stupid question but i am not sure who else to ask, so here it goes. AS some of you may know i am putting in the delta 272 regrind in my car. I also bought a Megan Racing 5 point adjustable cam gear. I finally had a chance to get the damn thing done, but when we tried putting the new timing belt on it would not fit. We have the right belt, i double checked. We moved the tensioner, didn;t help. We tried putting it on every single way. We then decided to put the stock cam gear up to the new one only to find out that the adjustable cam gear is bigger, not by much, but bigger, and if i had the stock one on the timing belt would be a hell of a lot easier to put on. I looked on megan's website and checked the product ID number to see if ti was the right came and it was........what do u guys think...are there special belts i need, or suthing?
Cam gear problems
count the teeth on the cam gear and the teeth on the stock cam gear.. if there the same then it will work.. ur just gonna have to work harder to get the belt on.. lol.. now do u have the right belt is the question?? if u do u should have some SLACK that u can use towards getting it over the cam gear...
Praise The Lowered...
This may be a little off the topic of your question, but did you get a special 272 regrind done? Because normally it is specifically made for naturally aspirated engines only. Unless you had them design some sort of special turbo cam you will almost surely lose power... I'm just curious because I'm looking for a cam designed for a turbo engine right now.
I can definitely concur with this statement. I spoke to delta on the phone when I was thinking of boosting the cb7 and they said they would build me custom turbo regrind. The 272 was for n/a specifically. Just FYI.Originally posted by Fearit22This may be a little off the topic of your question, but did you get a special 272 regrind done? Because normally it is specifically made for naturally aspirated engines only. Unless you had them design some sort of special turbo cam you will almost surely lose power... I'm just curious because I'm looking for a cam designed for a turbo engine right now.
