info on taking off ps belt
    was there a diy for this? i took off the belt.. and i like not haveing the ps.. but I want to get rid of all that bulk that is sittin here.. what do i have to do to do this.. ?? and what do i need to keep??? HELP lol
    oh.. and how much hp do u think is gained.. 5 ish?
    *on the lookout for an h22 swapped 5 spd accord*
    now for my P.O.S winter car/daily
    1992 4dr escort lx hatch
    NO MUFFLER-wrx sti tip(got fo free)
    5 spd
    You def gain power...
    I felt the loss when I put mine back on...
    It's pretty easy... Just get assloads of rags to prevent spillage and remove the PS pump from the head.. and the lines from that... the PS pump will oooze out PS fluid forever it seems like... and the lines too... You can just tee the lines from the reservoir and the pump in case you want to put it back in at some point..(good idea IMO). which will leave some fluid in the system and is a good idea because the rack & pinion doesn't like to run dry...
    unless you want to drain the whole system... tee the VSS lines and pack the R&P with some sort of grease to keep it happy... much less reversible...
    RIP Lifsatrip7
      im still confused.. like.. what lines do you have to run where? and i may be stupid.. but what does tee mean?
      5 spd
