did a search, and came up short. What wires do you splice together for the zeitronix widebando2? Do you get wires from the ecu or the wires from the 8(?) pin connector near the relay? just wondering where you guys spliced your wires together. thanks
wideband install
i wired mine right by the ecu connectors ...
use this diagram to help wire em up, for reference the power is yel/blk A25 and the ground is red/blk A26.
http://www.apexi-usa.com/pdfWiring/7...dfWiring/7.pdf
pg 33 has the pic, top right #H-2a
just hit me up on AIM if ya need help.
