ecu & nitrous question
    is there any ecu upgrades i could get while running nitrous?
    i mean like ive heard getting ur computer chiped and also running nitrous wont work out right, its either one or the other. is this true?
    because i want to send a ecu out to JEt to get it reprogramed, but also plan to run nitrous in a few months, so could i do this?
    thanks
    NEED RAP BEATS.....
    www.soundclick.com/akcidentaltrakz
    im not sure but i think JET reprograms MAY be able to reprogram it for nitrous..
    but i believe that has its side effects when ur not running nitrous power wise...
    also.. if u havent done so already.. u can get ur cam reground for nitrous.. which works reallly friggin well when nitrous is on.. not expensive either
    deltacam charges u around 100-110shipped for it to be reground..
    u wont be dissappointed when its installed.
    as for nitrous tuning..
    this is an expensive route but.. why not run a hondata and get it tuned for nitrous?
    youd see a bigger benefit.. because then when u add more modifications to ur car.. u can tune accordiingly..
    which is why i dispise chips..
    also.. a cheap way to go is a SAFC.. would allow u to run more fuel and fuck with ur a/f either way u go best of luck..
    man.. what is ur mods list again? i know u have a killa n/a setup so far.. just wonder what nitrous/cam/hondata would do to ur car
    Praise The Lowered...
      how much of a shot your gonna use i wouldnt use nomore than 50 make sure you have a cai,header,and custom 2.50 exhaust a fuel pump and a fpr just for good measure or else !BOOM! . Not talkin out the ask just talkin from experience and be sure to get it tuned.
        got one, but its gude 272 duration...lol
        mod list:
        exhuast str8 thru not cat w/ 2in pipe
        aem cam gear (not set yet waiting til i get her tuned)
        headers
        3in air intake
        bore JG throttle body
        mild p&p head
        adjustable FPR
        gude 272 cam
        full msd ignition upgrade
        no power steering
        throttle rotor
        and some more stuff, dont remember
        soon to come:
        p&p intake manifold
        and nitrous
        well im a start with a 50shot wet
        then eventually to a 100shot.....
        im biulding my motor for it, gona get the bottom end sleeved with Arias high compresion piston and rods and all the works done like next winter at GoldenEagle performance
        so yeah im biulding my motor, just gona get the 50shot next month and run that (running low 14's with it) til i get the bottom end worked out, then raise it to 100 but first 75 to make sure its ready....
        i got big plans .....
        NEED RAP BEATS.....
          Jet is such a ripoff...
          just like Hondata.
          blah.
          RIP Lifsatrip7
