are there any guides or anything to install header? im about to buy one but i need some guidance on how to do it cuz i don't want a shop to do it.. they charge like $150 for the job alone...
Installing Header
first of all you'll need a good lift to lift your ride to have an acces to the bolts/nuts under the car that connects the header to the exhaust pipe.. i think its pretty self explanatory? if you have the "OEM style" then it should drop in place like the stock ones.. from there just copy the bolt patterns the stock header has and apply it to the new ones ur trying to install...im thinking about getting headers for my car also and i havent done this kind of job too..but at least thats how i would do it..but make sure you have a company so if ever the car fells off the jack you got somebody to call 911..just kidding hehe..
Fast and cheap won't be reliable
Cheap and reliable won't be fast.
And fast and reliable won't be cheap"
~EYCEE~
On the head, yes. On the DP to header, no they are supplied. On the DP to cat, best get some new ones.Originally posted by srsskylineso can i use stock bolts? or need to buy new bolts and what size?Last edited by KillerCam282; 08-04-2005, 07:30 AM.
what about the gaskets i didnt get any.. so i went to honda and bought the exhaust manifold gasket and then i got two O ring gaskets... but i dont know if that will work with the 4 then the 2... cuz i saw online on ebay the pic of the gasket is diff cuz its like the 4 but instead its just two and then there is also a 1 which i think i need...
lots of penetrating oil and let it sit for an hour to do its job. the heat from the manifold tends to fuse metal together.
