hey guys.. my dad is a cnc machinest so hes gonna manufacture an EGR block off plate.. it goes on the manifold.. if you guys are wondering what good does it do heres the info i copied that sells egr block off plates.
ill post up pics when hes done making 1
__________________________________________________ _________
The EGR (exhaust gas recirculation) valve is an emissions control device which lowers the combustion temperature in the engine. A lower combustion temperature means lower NOx (nitrogen oxide) emissions. It accomplishes this by allowing exhaust gases to be recirculated into the intake manifold through a EGR valve. The exhaust acts as an inert gas in the combustion chamber which limits the effectiveness of the combustion event. Some people refer to this as "dirtying" the intake air so it won’t burn as well as it should. Ironically, the EGR emission control actually causes an increase in HC (hydrocarbon) emmissions.
This can be avoided by blocking off the EGR valve so the exhaust gasses can’t recirculate. Comes with a pair of CNC machined plates and instructions. This is relatively easy modification (about 30 minutes). Installing this will not only improve your combustion (which will increase your power) but the intake charge will become much cooler without hot exhaust gasses being injected into it.
