dtm mufflers type
    dtm mufflers type
    do any of u kno if they make silencers for DTM mufflers
    mines is sorta like this, but instead of being rounded, its blocked shaped.
    it has 2 holes in both muffler ports, so it looks like it has a silencer that might fit.
    NEED RAP BEATS.....
    www.soundclick.com/akcidentaltrakz
    As far as i know they don't make silencers for that style muffler. The holes you are talking about, which i assume are on the bottom of the tips are most likely for water to drain out of, so it doesn't sit in your muffler, and cause it to rust.
      a silencer would make a dtm sound more like ass than EVAR.. lol.. if u wanna quiet down the sound spend the cash on two things..
      1.resonator or turbo pack(second stage of a resonator)removes the sound alot more than a resonator would
      2.qtec exhaust valve..
      run the full exhaust daily nice mellow tone.. and run open header or where ever u put it.. for racing..
      my sisters cb7 was header back 2.5" no cat no res to a MR g2 prototype.. LOUDISNT THE WORD anyway .. i got her car running and she is considered a hazard due to excessive points ... long story short.. we go a turbo pack placed were her cat would have been. and man..its nice deep and mellow.. remove all the raspyness. sweet sound now.. and i didnt notice a drop in performance at all my .02
      Praise The Lowered...
        If you are going to do all of that work, you might as well get a nice cat-back, such as the thermal research. wicked, they don't make a "turbo-back" exhaust for a cb7.
        as far as i know The "exhaust diverter valve" is just a peice that allows the exhaust to flow through like normal, but if you turn the valve it will reroute the exhaust out of the valve, usually it is placed right before, or right after the cat. This is not a way to make H.p. and besides that it sounds like shit. Even if u were going to use it just for "racing" you aren't going to see any increase in H.P. in fact you will most likely lose some H.P because of the lack of backpressure
          got a cat back
          2.5 pipe, str8 pipe and the dtm.
          i think i just might get the resonator put back on.
          i want to quite it down some so i can here the motor instead of the motor/st8 thru exhaust
          and the little hose, ur right about that, i didnt even think of that.....
          damn, thanks
          NEED RAP BEATS.....
            your straight pipe cat is what's making it so damn loud. you should just throw the oem catalytic converter back on for daily driving and then swap it out for the straight pipe when you go racin'. that's what i used to do. that cat makes a pretty noticeable difference in sound.
              i know right, but mines is welded on
              my cat had to be cut off.
              i basically want to beable to pull up to someone and get into it without so much noise.
              i came thru waldorf and laplata last night (cops sitting all over the place)
              and was like if i got into it, they could spot me out easily...lol
              NEED RAP BEATS.....
                hahaha ohh shit
                meant turbo pack.. not turbo back.. lmao..sorry about the confusion
                and about losing hp.. thats odd.. when running open header u make more power.. with his mods i doubt hed lose any power maybe some low end tq but he might gain some top end who knows.. but its still food for thought the turbo pack mellowed my sisters exhaust down good ask steven h ite heard
