I ordered a generic ebay cold air intake and it came in. I can't seem to use the cold air, i can only use short-ram because the piping for the cold air wont go all the way to the fender, it comes short of the fender. Anyone got any sugesstions on how i can do this?
Cold Air Intake
Easy and simple
You have to line the cold air extention to where it will lead under your front end support. Using a whole saw kit and a power drill you will need to cut into the support for the cold air extention. It goes the same way for the intercooler set up. the pipe connects in the intercooler on the buttom but instead of the intercooler being there your intake cone will take the place of that. if you still dont know how to do it look for an installation guid on the net and it will show you. or buy the hynes extream import book. It gives you all the installing guides for just about everything you can install aftermarket on your car, they are step by step instructionsWhen you need something to cheer you up on a bad day..Buy a honda..
Esco
www.teamundergroundimports.com
http://www.cb7tuner.com/vbb/showthre...ht=cold+intake
browse through that. it was helpful to me. oddly enough if you browse the DIY section, you won't find this one in the list.....i searched for it manually and found it, and it said it was in the DIY section.....must be some kinna glitch i unno.
