ok so i got my UR pulleys installed yesterday...took me over 2.5hrs. breaker bar, impact gun, nothing worked....so i took a torch and heated the bolts up. even the p/s and alternator pulleys were difficult to remove ugh. and the belt numbers that UR gave me were correct. no squealing, no abnormal noises, nothing wrong. in fact they run quieter than the stock ones!! the power....huge ass difference and i still have to really break the belts in, do a final belt adjustement and let the comp do sommore adjustments but it is by far the best upgrade(power gain wise) i have done yet. the weight difference was insane. the entire wieght of all three pulleys were little under 2lbs. the stock crank itself was over 5.5lbs lol. and it was nearly double the size of the UR crank pulley. now i have a pretty kicking system and i haven't had any issue with that or even lights dimming at low rpms.
another satisfied customer of UR pulleys!!!!!!!!! if anyone was thinking of getting these pulleys.....do so!!!! parts including the belts were under 300...288.37 to be exact
me don't mind
