Hello,
If I get a wideband O2 sensor, I need to run the computer in the mode where it doesn't modify the fuel mixture. I can't remember if this is closed or open loop. My question, though, is simple. Can I run the computer in that mode and simply replace the stock O2 sensor with the wideband O2 sensor. Then use the ECU's datalogging feature (by wiring a USB cabel to it) to monitor the wideband's output?
Thanks for the input
edit:
What kind of drivers do i need to install for my XP box to read the ECU's output over the USB stream into uberdata?
edit:
