Okay people heres my next problem or ponder on something. Now i have a autometer a/f ratio guage it reads lean then it goes out on its own now does this guage rely off the o2 as well as the catylic converter to give it a more suitible reading?
hmmm A/F guage not reading right
Andrew
It only gets readings off the O2 sensor, there's no feed from the cat.
An A/F gauge on the stock O2 sensor is just a lightshow. You need a wideband to know anything other than that there's air and gas pumping through the engine.
Andrew
An AEM UEGO Wideband with gauge [with center digital display] can be had for $500 now. Kudos to AEM, it's a great innovation on a great product.
Andrew
You would connect it to the o2 signal wire either at the ecu or the near the o2 sensor. Don't remember which color wire the o2 signal wire is though.Carlos
My Members Ride Page
