I just installed a Field's Boxer series VTEC controller on my H22A w/ p13 ECU and am having a few problems with it. When the Unit is not plugged in the car runs like shit and I get a CEL the weird thing is I get codes 06,10,20,21,22 which 21&22 aren't codes. I got these codes before right after I had the car running and was having TPS problems also. I reset the ECU and checked immediately afterwards without running the car and I still am getting a code 22.
When the unit is plugged in and off the car runs perfectly fine however when the unit is on and all settings are set to stock settings I redline at 6500. There is a setting for a buzzer. In the paperwork I found online that is all this function is for however wherever I set that buzzer is where VTEC will disengage and no buzzer comes on.
Do you guys have any suggestions? Do you think I recieved a faulty ECU with my motor. The car has always ran fine and I have had no problems out of it after all the faulty sensors were replaced. I know it says if it throws any codes other than the ones listed to replace the ECU but do you guys think this is necessary?
