Ok I got a h22 auto tranny If I buy the 5 spd tranny will it fit exact though
h22 auto
Yea you will also need to get that plate, flywheel, and clutch assembly if you want the 5spd.
No it won't fit exact. The h22 auto fits exact. I had not problems it my intall. As long as its is auto to auto. Auto to 5 speed is different. Depends on which tranny you speak of. If you do a h series tranny while using your stock auto tranny mount you can use the 4th gen lude tranny mount or the 5th gen accord tranny mount using (2) 3/8" spacers on the drivers side mount and it will fit exact. along with redrilling a new tranny hole if you don't go the spacer route. If you go with the f series tranny you need to reweld with the cb7 5th speed f22 mount.91 Ex CB9
JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
W.I.P.
p72 ecu on Hondata
To Come
Weight Reductions
R33 or R34 front end
