I'm going to get rid of my Magnaflow muffler, and I was thinking of getting a Flowmaster. Has anyone had one on there car, or ever heard one on a CB7?
Flowmaster
Up Until Recently I had a glasspack on my car, now I have a flowmaster 60 series (I got a 272 grind, making the car horribly loud and obnoxious with a glasspack) and I don't want to say the 60 made it exactly more quiet, but it totally changed the tone, completely put a stop to any rasp experienced with a straight through setup. It makes a pretty cool harmonic sound at high speed high rpm as well, around 90mph it makes a sound almost like it's singing.
Hard to describe, but definately worth it if your car produces a lot of noise and you want it to sound more mellow and mean.
Just a warning though, until they warm up flowmaster baffles make a horrible rattling sound.1992 Accord EX Coupe
Shortram Intake
Matrix Coilovers
Front + Rear Strut Braces
Custom 2.25 Exhaust
Flowmaster 60 Series Muffler
Delta 272 Regrind
Slammed, Stripped, And Loud
I Have A High Flow Cat On 2.25 Inch Pipe W/O A Resonator, The Flowmaster Cuts Down On The Rasp, It Makes It Into A Different Sound, I Figure High Flow Cat + Camshaft It's Probobly Just As Loud As A Straight Pipe, The Flowmaster Definatly Cuts Down On The Rasp, It Still Pops And the Baffles Rattle When It's Cold, But It's Nowhere Near As Bad As The Bee In A Can Sound.1992 Accord EX Coupe
Shortram Intake
Matrix Coilovers
Custom 2.25 Exhaust
Delta 272 Regrind
If I Were You I'd Pull A Bubb Rubb And Trip Out The Flows Then. It Sounds A LOT Better Than A Straight Through Exhaust, And With A Camshaft People Will Hear You Rev And Give You Bizzare WTF WAS THAT Looks.
For Instance, My Car's Cam Lope Produces An 'I'm About To Explode' Sound Because Of The Flowmaster Growl. It's Hard To Describe, I'll See If My Friend And I Can Get Some Soundclips Later.1992 Accord EX Coupe
Shortram Intake
Matrix Coilovers
Custom 2.25 Exhaust
Delta 272 Regrind
OK, I got my exhaust re done, this is my set-up... Chikara header, 12" glasspack to replace the resonator,Flowmaster 60series muffler with all 2.25" pipe. The problem is ever since I got the car it makes a tin can sound when it gets around 2or3000 rpms. It sounds fine when I'm just crusing easy, but as soon as I go a little quicker it sounds like crap. I've had ever thing from all stock exhaust to header straight to the muffler. Nothing seems to kepp that noise away, has anyone else had this problem or know how to fix it. Now I'm thinking it may be something to do with the motor internals, which by the way is a F22A6, automatic. ???????
