Ignition upgrades?
    Ignition upgrades?
    I want to upgrade my ignition. Ive got an internail H22. Dont mind switching to external. No major mods now, I just want some headroom for the future. Any recomendations?
    msd 6a? better wires/plugs...
    Shift_BOOST
    BOOM!
      just recently installed the MSD SCI along with the blaster 2 coil/nology hotwires/NGK iridiums i've been using. all i can say is i should have done this a looooong time ago; IMO, the car starts up quicker, idle is alot smoother than before, and throttle response has definetely improved.
      5.6L V8 32V DOHC
      JDM HERITAGE - US BUILT
        ngk v power.... with .050 gap Blaster SS coil..... msd 6a / better wires / plugs.
          What exactly does the SCI and the 6a do? Do they replace the ignitor?
          EDIT: At this point, if im getting into upgrading my ignition, would it be wise to upgrade the fuel pump, get some kind of FPR, and get like a chipped P28 or something?
            well the 6a provides multiple spark............aka M.S.D = MULTIPLE SPARK DISCHARGE... which shoots 3 sparks during each firing of the cylinder...but once the car reaches 3000 RPM and higher...the MSD 6a really has no purpose....
            the blaster SS coil...replaces ...the stock coil... and what it does is provide a spark @ 45000 volts rather than 30000 volts that the stock one does
              Ahh... so right now, once my car gets above 3K, it will occasinally misfire, and has a bitch of a time crossing over to vtak. Im assuming this is spark related, and I would benifit from the SCI moreso than the 6a? What exactly does the SCI do? Is my ignitor shot?
                just finished my upgrade (6A, blaster 2 coil, msd dist cap, ngk wires and plugs)...i like it...ditto what PRIMOCB7 posted.
                My Old Ride Thread
                  the 6A and SCI does the same thing. no difference, besides the exterior color of the two. and at higher rpms, the MSD ignition boxes help improve overall spark throughout the rpm range.
                  93EXaesthetic, you've been mis-informed about the MSD having no purpose after 3k rpms. one of the main reasons why people use MSD ignition boxes is for that reason when reaching higher rpms, it helps prevent misfires.
                  5.6L V8 32V DOHC
                    Sweet, is one suprior (kant speell) to the other?
                    Sorry, for the noobish questions!
                      nah, the SCI was just marketed for imports/sport compacts. if you can get the SCI for a good price, cool.. but the 6A is exactly the same thing and they're usually priced slightly less.
                      5.6L V8 32V DOHC
                        Sweet! Thanks man, so I should be getting...
                        -SCI (or 6A)
                        -Blaster 2 Coil
                        -MSD Distrubitor Cap
                        and new NGK plugs. I should probably replace the rotor too, does MSD make them? ive got OEM NGK wires, should I be upgrading those too? I bought them new when I swapped. Should this smooth out my powerband?
                          -SCI (or 6A)
                          -Blaster 2 Coil
                          and new NGK plugs. ive got OEM NGK wires, should I be upgrading those too? I bought them new when I swapped. Should this smooth out my powerband?
                          the majority favors the NGK wires and i see nothing wrong with them either; i'd recommend the MSD wires if you want to upgrade. and the plugs.. got some good news, i've got an extra set of NIB NGK Iridiums for the H22 (sale plug )
                          5.6L V8 32V DOHC
                            Advertising blather.
                            The coil will spit out what is required to jump the gap, not one volt more.
                            2003 Maxima SE Titanium Edition
                            1993 Suzuki GSX1100F 136bhp
                              Now that im looking at stuff, if i have the SCI, I dont need to get a balast resistor w/ my coil, correct?
                              EDIT: For those of you that are running a JDM H22, what cap and rotor would you want to get?
