I have a f22a1, and i have read on other forums that the f22a6 intake manifold has dual runners, which is like 8 inlet hole for air opposed to the 4 on the f22a1 intake manifold. I also heard that you can swap these out prety easily. My question is can i swap these without an ecu swap, or will i have to get an ecu as well. And i fi do need an ecu will it have to be from a automatic tranny car since my car is an automatic???
I want to do this next monday but i wanna make sure its worth and and i can do it easily without pobelms
You'll get the same answers here as u would on AT. Try to stick to ecu's compadible to ur tranny but it doesn't matter any ecu from 90-93 accords WILL work. You don't need an a6 ecu...you only need it if u want to have the butterflies closed before 4700 rpm. If u don't have it then they will just stay open all the time like mine.
