Wondering if this would work . just a yes or no would be great . Thankz
H22 intake manifold on f22 a1 ?
I thought they had the same port/bolt patternOriginally posted by 93accordexcoupei thought the h23 would but the h22 wouldnt
Guess not.Originally posted by PRIMOCB7the H22 intake manifold DOES NOT bolt onto the F22ax motors. the bolt pattern on the lower phlenum is different. BUT, the upper phlenum of the H22 is the same as the H23; those can be bolted onto the lower phlenums of the F22ax motors.
Not really...I don't wanna get into this debate again but it's definitely possible to build an F to H power for less than H money...the H22/H23 plenum is a part of that equation...Originally posted by h22sparkleuseless
And yea from what I know you need the A6 lower manifold and ECU and either the H22/H23 plenum.
H22 upper plenum and H23 upper plenum are the same. F22 upper plenum has the same bolt pattern but is smaller. all plenums are interchangeable, as long as you use the right TB (H series on H22/h23 plenum, F series on F22)
H22 lower runners will only fit an h22.
H23 and F22 lower runners are different but both fit on each others motors.
All dual runner IAB plates are the same.
that being said, you can use H23 lower runners (not h22) and an H22/H23 upper plenum on your f22.
