As the title says...whats the best way?
Best way to get speed limiter off JDM H22A?
get a chipped p28 or p72 (p28 doesn't look for the useless-as-fuck honda knocksensor, is cheaper and doesn't need and EGR valve either, i'd go with it)
the p13 sucks, the p72 is annoying and a p28 chipped to work with DOHC VTEC engines is cheap, plentiful and helped me run a 14.1 with minimal mods....same setup with a p13, tuned to hell and back, got me a 14.7....and on the 7th day, deevergote rested and called his mom.
you can go with the p28 but remember make sure its chipped properly with a h22 baseline map that is reliable and stable or else youll blow your shit up. Get it tuned properly. The p13's run rich which is like a honda dummy safety method so that you dont run lean. Everytime you mode the car and make it breathe a bit more the more richer it gets.
yeah I'm thinking about getting a p28....I'm trying to get a hold of MRX atm and see how his baseline map for the h22a is going. if anything, he only live like 4-5 hours away from me. I can take a trip up there or something and have him tune it right. any one have exxperience with his chipped p28's for the H?
i ran a chipped p28 for quite some time in both my accord and hatch. and when i mean quite some time....i have had an H in my accord for nearly 6 years and nearly 4 years in my hatch.
My accord has a stock h22 with bolt ons and over all teh best ecu for it has been a tie between a USDM p13 with Dinan program or a chipped jdm p13 with vtec lowered to 4700 rpm and rev limit upped by 200 rpm with stock fuel/ignition maps. Then again currently I am running a stock program again....it works and it works well.
The civic and accord both got p28s for quite a while. The civic currently has a Hondata s300 p28, and before that a Crome tuned p28. The civic has also had a Euro-r manifold and currently has a skunk2 manifold. The civic is also set up as a pretty much dedicated track car though....
In general I have found hta tmost p28s tend to run the fuel a bit on the rich side for the h22, and for some reason people like to disable a lot of sensors on it as well which makes the problem worse...
Originally posted by v4lu3sIn general I have found hta tmost p28s tend to run the fuel a bit on the rich side for the h22, and for some reason people like to disable a lot of sensors on it as well which makes the problem worse...
plus p13s do run rich..H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
Originally posted by phatdoughnutthats why you have them turn the fuel down, that is the purpose of having a chipabble p28. So you can tune.
and how much fuel do you "turn down?"
unless you are going to do some tuning a p28 is gonna be too rich most of the time.....even then you never know whats up, i made a nice program for a custoemr that ran a 13.4 in his hatch, and he cant drive. with the same program i was not able to get down below a 13.9, i was running extremely lean....like hurt the engine lean...so i actually had to ADD fuel back up top and all of a sudden im doing 12.9-13.1
actually p13s do not run rich, the past 6 eyars of emssions testing on my car prove it does not run rich. also 25-28 mpg in a wagon indicates it is not running overly rich either. Then once you add an intake, and exhaust etc you lean it out further....
Originally posted by 93Akkordwell i have the JDM p13 right now. what chip would you suggest for it? cause lowering the vtec to 4700 and the removing the speed limiter is just fine for me.
my recomendation is find a competent Crome tuner and have those things done. Gooberdatais pretty worthless for p13s afaik.
p28 with a p13 h22 basemap.
You dont run a stock p28 with out it being chipped and socketed on an h22. But i am sure you already knew that. Maybe thats why you've had bad luck?
And you are right, you do have to tune it, every car runs differently, so it only makes sence to tune the CHIPPED P28 to your application.H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
Originally posted by phatdoughnutHow is the p28 gona be to rich? if you are running an h22 base map? you are contridicting your self.
i only have been running chipped p28/72s on h22's for over 4 years now. I also am a Crome Pro owner, Hondata s200b with romeditor owner, Hondata s300 owner, have 2 widebands, and a usually 6-12 ecus on hand at any one time and enough solder and parts to chip them all and still ahve left overs....
unless this guy takes the time to have it tuned teh p28 he is putting in there is going to be WORSE in most cases than a p13....and for an engine that is internally stock without a high end header such as an an-r at minimum plus every other bolt on he is wasting his time and money on buying a new ecu and paying for chipping and tuning when a p13 can be chipped and modded to do just as well at far less cost.
