hey i have an h22 motor that may need new injectors....i dont want bigger injectors as i dont have an after market ecu that can be tuned to accomodate such..but rather i want to have stock or slightly larger injectors that can be used in accordance with my stock ecu.....
injector help
i am not sure i need them i am going through the elimination process....all of a sudden the car started running like complete shit..like its starving for gas...the engine has no more than 36000 on it when i bought it...since then i have rebuild it changed all seals and gaskets....but i cant seem to figure out why its running like that.....(fuel pump, and filter are good)...gonna swap the injectors to see if that is the problem....all else i will check the head.......
what u think?
don't just throw parts at it and hope it fixes it. that can be expensive.Originally posted by strongpantsi am not sure i need them i am going through the elimination process....all of a sudden the car started running like complete shit..like its starving for gas...the engine has no more than 36000 on it when i bought it...since then i have rebuild it changed all seals and gaskets....but i cant seem to figure out why its running like that.....(fuel pump, and filter are good)...gonna swap the injectors to see if that is the problem....all else i will check the head.......
what u think?
get a haynes manual and go to the troubleshooting section.
but, sense you have a swap, it's probably a wiring problem....check your grounds, one may have poped off. later.
