what to use for a header gasket?
    i am so sick of this damn ebay header. this piece of shit wont hold for the life of it. the bolts that hold the down pipe to the exhaust manifold keep loosening up. this time when they loosened up they destroyed the gasket. what should i use for a gasket and what do i do to prevent the bolts from loosening up? any info will be appreciated.
    thanks,
    David
    it's been a while but i'm back!!
    just torque them down tightly, use common sense and maybe loktite, but I find once it heat cycles for a week or so, the bolts are on their good until you physically remove them. any high heat gasket material will work
      only way to go with a GOOD header is a copper gasket. little more expensive but will last 20 times longer and create a good seal. as to the bolts, torque them down to specs, run for a week then retorque down to specs. the constant hot/cold will cause gasket to seat lil better and in turn u may need to retighten the bolts. when i installed my header, i retightened 2x. ran car for 15min till normal temp. then shut off and tightened again then retightened after bout 5 days. good luck
      My members ride thread
