compression testing
    compression testing
    Okay i search here and on google and i found this on diy compression testing http://www.dsmgrrrl.com/FAQs/compression.htm ... the question is would you rather pay someone or try this and if you would try this or have done your own before can you tell me in cb terms how to diy a compression test.
    Dont drive faster than your gaurdian angel can fly
    you can buy the gauge for 40 bucks at napa and do it yourself, it takes me about 10 minutes start to finish, its def worth doing yourself
    1993 CB7
    2001 BB6
      It's not that hard to do, get a compression tester like ^^^ said.
      That link you posted looks like a good DIY guide. Make sure there is NO spark, NO meaning NO SPARK!!!
      be sure to do wet and dry tests...the compression numbers should be even across each cylinder.
      If you dont feel comfortable, just take it to your shop and let them do it...though, most shop guys are lazy when doing compression tests: they wont average out the numbers and/or do it only once.
      1990 Accord Lx F22a1(Daily) SOLD - will be missed
        where can i disconnect the injector fuse and the coil connector from the dizzy? and then you crank attempt to crank the car or what from there....i read this thing like four times and still aint getting it and thanx for the positive replys so far.
          X2
