starting problem
    starting problem
    well i got my accord registered today after having it since feb 05 . it was running good but now after it runs and then you shut it off... it will start right back up, then stall. if you try to start it again, it just turns over. after about 5 minutes it will start again. now on my yfz 450 (fourwheeler) i had the same problem but it was a sparkplug i think. im not sure what this could be so if anyone has any ideas i would appreciate it.
    i had this same problem, but with mine i was the ignition switch, my friend also had this problem, but his was the fuel filter, when was the last time you replaced it?
    Members Ride
      main relay
      do some searching on here for that and you'll find out exactly what you need to know
        yea i searched a little under "starting problems" but didnt find it. ive never replaced the fuel filter but im not sure when it was changed last. so it could be either of those three or is it the main relay for sure?
          90% sure its the main relay, it does it mostly in warm weather right? espically with the car sitting in the hot sun with the windows up
            well it only does it after i run the car and then try to start it. if the car has been sitting it starts no problem. it seems like with the main relay problem it just wont start at random even if the motor is cool. so im not sure what else it could be
