Originally posted by d112crzy
header comparison
You might as well stay stock-o... DC style headers do nothing for the HOriginally posted by starchlandhaha 800 for a header give me a break, ill keep my 700 bucks and stick with my megan.
I'd rather spend that money on cams
for 270 shipped u can get a kamakazie 4-1 header
headaches like how, are you sayin that 4-1 header on s stock f20a is a bad thing
Originally posted by F20A CB7headaches like how, are you sayin that 4-1 header on s stock f20a is a bad thing
No, they just aren't very well built.
Hondafan81 has one on his red project and he has had several issues with bolts loosening, and leaks and rattles developing.
Also, I DO have the DC Sports with 2.5" downpipe, as well as a standard 2" collector.
As soon as I can get my 2.5" cat welded up and ready to go, I will see if I can't get some dyno results on the differences.
Money is going to be tight for sometime though, so it might be awhile.
Installed new OEM exhaust manifold gasket today, had to remove the manifold part of the Kamikaze header. I realized that my manifold-to-downpipe triangular flange gasket is holding up, not distorted. No leaks.
Anyone getting a Kamikaze header, I suggest ditching the 3/8" coarse thread bolts they give you and hex nuts. Get 3/8" fine thread bolts with all metal locknuts, reuse their lock washers, then you'll be set. Obviously put the lock washer and locknut on the same side of the flange. This seems to work, it's the third setup I've tried.
Invest in a 9/16" swivel socket, you'll need it with extension/ratchet to attack from top, while holding 9/16" combo wrench on bottom (2 person job). Careful attacking from top not to round off hex heads, you can only get on it so much before you cock because of the heads being so close to downpipe. I'd also look into your primary ports in the header, see if it's offest a bit from flange....if so like mine, do your own portmatch before install. I also suggest putting Permatex copper gasket on both sides of your new exhaust manifold gasket thinly, mine for some reason took about 1 yr to develop an exhaust leak, I don't know why. I'm doing it 2nd time with RTV as added precaution cuz I hear it works.
Previous setups tried:
- what they give you for fasteners = fails in 6 months or less
- 3/8" fine thread, lock washer, fine-thread hex nut = fails in similar time as aboveLast edited by HondaFan81; 05-04-2007, 01:09 AM.
