air fuel gauge blinks?
    my af gauge blinks .. .it goes through the different colors of stoich ...lean and rich...but it blinks every 3 seconds..like an update..rather than stay on like it should
    when i disconnect the af gauge signal wire..aka as the purple wire..and rub my fingers on it.. it goes from red to yellow to green... this is when the cars ignition is set to phase one.. so im guessing everything is connected correctly except for the signal wire...
    i have changed the ground wires position several times..so i dont beleive its the ground wire..
    it has something to do when the car is running...when the car is on .. .or i have the purple signal wire on the incorrect ECU wire...
    i just got a new o2 sensor.. so i know this is not the problem....
    im thinking of wiring it directly to the o2 sensor rather than the ecu..any suggestioins people will help thanks.. its annoying ...
    btw its an autometer procomp if anyone was wondering..
    i forgot which pins i hooked it too.. to lazy to look right now... ill post laterz..thanks for the hellp...
    im thinking of just connecting the signal wire directly to the o2 sensor... im just not sure which wire i need to splice into ...which color..thanks again.. out.
      thanks d112crzy problem was power hooked it directly to the battery and walah...thank you all for your suggestions
        joser ftmfw once again!
