where does the secondary butterfly for a dual stage h22a manifold go connected to??? mine is plugged up with vaccum and a check valve
h22 intake manifold?
Lol yeah but where is that vac line running too ? If its connected to the manifold then its going to open near full throttle.. If its connected to the black box thats under the manifold and its wired up to the ecu then it opens at like 4500 rpm's.. I just did the swap onto my f22a1 and just ran a vac line from the manifold to the (goldish flying saucer looking thing) = opens near full throttle.
Id hook it up to an open vac nipple. They should stay closed at lower rpm's to help make torque then open at higher rpm's when the engine can take advantage of the extra air flow. Ya know how a engine can flood with to much fuel ? Well its kinda like that with air too. to much air to soon and you will lose some lowend power. So with it ran to a nipple it gives you the best low end hp/tq then opens up at higher rpm's to get max flow. Thus you get the best of both worlds. Good low end (when closed) and great top end (When open).
Yep thats how I have mine ran didnt feel like doing the IAB thing for p28. It opens around 4500-4700 in that range. And any vacuum off the IM as mentioned will work.
Originally posted by nightrider93exohh nice....oh ok look it has a vaccum line but its just there no knot or anything....just a vaccum line connected to NOTHING....should i leave it like that??
Take the advice of people though and hook it up to a intake manifold nipple that's open and make sure all others are plugged up so you have no leaks.
