vacume box on itm
    vacume box on itm
    I know this is kinda a noob question but oh well. The vacume cansiter on the bottom the the itm on a 95 USDM H22, WTF is it for? im not sure if its for the secondary intake butterflys or what? Yes i did search and all i got where a bunch of people with egr problems. Any info would help, im not looking at taking it off i just need to know what it is
    New cb, new start
    iab vacuum canister. black plastic box holds a vacuum, and the ECU tells the solenoid to open it up and it pops the secondary butterflies open via that silver plunger on the side of the itm.
    vacuum line w/ check valve from nipple on manifold to black box, from blackbox to solenoid, and from solenoid to plunger.
    two pin connector - black/yellow gets +12v (can be tapped at distributor, plenty of black/yellow there) and the other goes to the ECU.
      Thanks mike, by the way your car is the reason i bought my cb7, thanks for the info
      New cb, new start
