Hi guys..been looking at a bunch of F22 basemaps lately deciding what would be a good start for in vacuum. As far as i know no one has done extensive load based dyno tuning to get best power at each load and RPM. Therefore we're somewhat limited for NA tuning.
Although, MRX did play around a lot with trying to make more power on an NA car.
Seems like from our low compression that people can throw a lot of timing in with no mal effects.
Also, these maps are basically designed for 87 octane, so when we start running turbos and 93-94 octane it's not unreasonable to add more timing to the NA map as well.
From other further reading, aparantly the same maps in uberdata will actually add more timing than the same maps in Crome. Not sure why...but just what some tuners have found in the past.
Ok, well here are some screenshots of the maps i've found.
Here's the p12 (JDM F22A ecu)...aparantly some have made more power on this ecu than the stock pt3.
P39 ecu - F22B DOHC.
Maps straight off stock rom. Now this might make sense in that if a head takes in more air it would be more explosive and burn faster...thus requiring a lot less timing. Quite a big dip at maximum torque.
P14 - H23 ecu
Similar. Higher CR but bigger bore, so take it as it is.
MRX distributed F22a 14b (boost columns not shown...but i'd say the boost section is nice in that he adds a nice dip where it spools and overall timing is pretty good...where i based my map anyways)
My current NA map...more or less a modified GSR/H23 basemap. Run on my F22B dohc.
D112's F22B basemap.
Now from these results...i'm leaning towards using the F22B mostly but adding more timing in near WOT to account for better octane fuel...perhaps bring it closer to my hybrid or MRXs map.
What are any of your thoughts on these maps...tuners chime in, and if you have any maps to share that would be cool too... i think we should set up some sort of repository for them with descriptions...i could probably host it on my school webspace, but just as a download center (no webpage for descriptions...possible readme though).
Mark
P14 - H23 ecu
Mark
