i was wondering what are your opinnion on h22 swaped in a 94-97 accord. is it reliable?? is it worth it?? anything i should look for after its installed???
how reliable is h22 in a 4th gen accord
It's about as reliable is the install...
If you cut corners reliability goes right down the crapper...
otherwise, it'll be just like stock... usually... alot of people have little gremlins that they are chasing for years to fix... and honestly some never find the gremlins and just live with it...some have zero problems whatsoever though... leading me to believe that it's 150% about the install and research beforehand...
That's the reality...RIP Lifsatrip7
Just keep in mind, whenever you start trying to "out engineer" Honda, you will run into some problems now and then. That car was not engineered to have that motor, period. That doesn't mean it won't work, it just means it won't be quite as reliable as the stock setup. Don't get me wrong, thats not necessarily a bad thing, its just part of hot-rodding. To answer your question tho, for the most part, will it be reliable? yes. Will it be as trouble free as the stock setup? probably not.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
