anyone know if k20 piston will work with our rod. they'er 86mm, and most ppl say you can bore safely to 86mm. so i think it would be a good option....that is if they would work
k20 pistons
hahha badazz sig bro!
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
You can try it. Just make sure clearances will work. Are you going to get aftermarket rods with em too? Might wanna check the wrist pin diameters and such to see if they are similar to ours.
From what I understand, the valve reliefs are at a different angle. They can work depending on your compression height and valve lift. The quick fix would be to get custom rods. The stock rod lengths will not work in the F22.Originally posted by mtnickelboth the wrist pin and the compression height are fine. The only thing i found was that there were no options for turbo compression range...only higher compression really. Other than that, you'll want to check the valve recess locations and angles...don't want your valves to hit.
