Cam gears, how important are they?
    So i have been told before that if you have cams that are made for your car (not stock) that you dont need cam gears. How true is this? i know that the gears are for fine tuning and you can adjust you power range around with them but really how much gains are you actually going to see.
    Thanks
    Quite a bit of you tune it right. You can play with the overlap on cam gears its good stuff just dont get too extreme with them and mess something up in your motor =D. But any place that tunes should be able to extract quite a bit of power out of it. I really dont see much gain with a cam gear for SOHC cars but some get decent gains. ON DOHC cars on the other hand because of the ability to control the intake and exhaust cam you have a wider range of tuning you can do to the engine.
      yeah i understand the process but i have heard of cars that have them and havent gotten much if any gains out of them.
        Might wanna give this a quick read
        http://forums.evans-tuning.com/viewt...e57f86fb172b04
        ...adjust accordingly
          If you haven't done anything major to your engine, I would leave the cam gear how it is because the engieneers at honda put it how it is right now for the best performance. Other than that, it is a suportive mod. Without other mods, it would be pointless.
            good find def imformative but lets say i have cams made by delta that are personal for my car you think i would get the hp that he was talking about from gears?
