Throw CEL Code 43 fuel supply system?
    Well one day i was just cruzin down the highway and all the sudden my check engine light turns on and pull over and get out my paper clip and read the blinks and it blinked 4 slow times and 3 fast so thats code 43..Which is fuel supply system? what in the heck is that? and what is the problem?
    thanks
    josh
    Project EX Coupe Coming Soon...
    ..::Built not Bought::..
    x2 bump for that, I had this problem once too!!!
    H22-T FTW!!!
      Bumpppp I Had This Code Before I Started To Turbo It I Changed My Injectors To 550CC'S I Installed A Walbro 255 Hp Fuel Pump I Installed A Aem Fuel Rail And Fuel Pressure Regulator So I Hope I Solved The Problem. I Guess Ill Have To Find Out When The Time Comes To Start It Again. But My Old Injectors Were Mismatched I Had 3 Alike And One Different So If Anyone Can Shed Some Light To This Problem It Would Be More Than Helpful
        Josh26
        I dont think u have to go all out like your boy xtremecb7.... Get a volt meter and test ur line to ur fuel pump... That would be one of ther first things I would look at. Also look and see if its just a fuse that went bad... then u can start lookning into fuel pump and injector issues...
        My Members Ride Thread ( Do It )
          had the same problem on a f22dohc.....ended up being the o2 had a wire crossed.....fixed it no more MIL......
          F22A1:blew up
          F22A1/H22:blew up
          F22A6/H22: " "
          F22A4/H22: " "
          H23A1 boosted:blew up
          H23A1:traded
          H23A1/H22 built:still in progress (getting my feet wet)
          drive it like you stole it
          FCB7(FRANKENSTEIN CB7 CLUB)
            thanks
            josh
            whenever i had this problem it was ALWAYS my o2 sensor, its part of the fuel system cuz it tells your injectors how much gas to give
              x2 on the O2 sensor. I've had this CEL before and after I boosted the car, I also changed everything fuel system related, pump, filter, injectors ect...and the CEL continued, so then my tuner disactivaed the O2 sensor and the code went away.
              SOLD!!
              Boosted H22
              375whp 298 ft/lbs at 15psi
                o2 sensor.
                it has eyes!!!
                  i changed my 02 sensor and the cell comes on from time to time. <<<< it somes on mostly only when i come out of the high way.
                    Yesterday I was driving and my car threw a code 30 - Automatic Tranny Signal A
                    My car is a Auto to 5 speed conversion and I've had it this way for years. Maybe it's still confused what it actually is.
                    My CB7 is now ***FOR SALE***
