ok so i had excessive wear on my cylinders walls and i wanted to resleeve but was convinced by the machinist to just bore and hone... it ended up being a .020 bore which is a little more than .5 mm... now i have read that anything over .5 mm ruins the sleeve. is this true or what?
h22 ruined?
Originally posted by newtuner7the machining costs were covered by my dad so i dont know how much that was.... i will speak with my machinist tomorrow he may cut me a deal since he was the one that told me to get it bored before.
normally, people will respond pleasantly to that all out assault....and on the 7th day, deevergote rested and called his mom.
there are several companies that make oversized pistons, but most require that it be resleeved as they are forged pistons and the frm sleeves are not adequate for forged pistons... the thickness of the fiber seems to be .5mm which is a bore of .020. so it seems to me that to be safe i need a resleeve.
Originally posted by rickyduckworthyeah, the machining is the expensive part usually. be a bitch and slap him then tell him you'll sue him and then murder his family.
Originally posted by newtuner7there are several companies that make oversized pistons, but most require that it be resleeved as they are forged pistons and the frm sleeves are not adequate for forged pistons... the thickness of the fiber seems to be .5mm which is a bore of .020. so it seems to me that to be safe i need a resleeve.
