so im buying an h22 and i've been watching videos on you tube. i have seen some baddass h22's with itb's and i have seen some sick h22 turbo's beating lambo's but im not sure which to do which would you guys pick also do i need to have it sleeved?
n/a or turbo
Personal preference. NA if you dont know anything about boost. Funny thing is big turbo fwd will beat most anything at a roll but fail badly at a dead stop unless you have full slick on or something of that nature.
do more research on both and it will give you a better idea of whats involved. have a power goal set. are you doing a street or track car. a good n/a build can be just as expensive as a turbo build. n/a you get raw power. and itb are bad ass but it has drawbacks. turbo you get delayed power but a greater output of it than n/a. take in mind the weight to power ratio. the more weight your car has, will slow its potential time wise in a race. the main factor is time and money. do it right the first time and your better off. get the best tuner you can. good parts and a turner can make or break you regardless the direction your going.91 Ex CB9
JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
W.I.P.
p72 ecu on Hondata
To Come
Weight Reductions
R33 or R34 front end
Originally posted by flight50do more research on both and it will give you a better idea of whats involved. have a power goal set. are you doing a street or track car. a good n/a build can be just as expensive as a turbo build. n/a you get raw power. and itb are bad ass but it has drawbacks. turbo you get delayed power but a greater output of it than n/a. take in mind the weight to power ratio. the more weight your car has, will slow its potential time wise in a race. the main factor is time and money. do it right the first time and your better off. get the best tuner you can. good parts and a turner can make or break you regardless the direction your going.
I was in the same boat as u was. I was at first going N/A. BUt my boy wanted to put a turbo on his car. SO he got me thinking about turbos then. SO i did the research and decided to go with a turbo. ANd i love it. No matter what u do to a H22 N/a, it will never produce the torque and Hp that a turbo would.Everybody i took for a ride in my car, they want a turbo on there car now. I would say get a chance to exprience a turbo honda, then make your decision.BUt when it comes down to it, do whats best for u.If u dont know how to do a lot of our own work on your car, then i would recommend u getting a turbo.
Originally posted by jm991700I was in the same boat as u was. I was at first going N/A. BUt my boy wanted to put a turbo on his car. SO he got me thinking about turbos then. SO i did the research and decided to go with a turbo. ANd i love it. No matter what u do to a H22 N/a, it will never produce the torque and Hp that a turbo would.Everybody i took for a ride in my car, they want a turbo on there car now. I would say get a chance to exprience a turbo honda, then make your decision.BUt when it comes down to it, do whats best for u.If u dont know how to do a lot of our own work on your car, then i would recommend u getting a turbo.
your the prime example example why someone wouldn't go turbo.. i took my buddies for a ride and now they wanna go turbo.. everyone and their mom is going turbo in honda's these days just so they can produce power for cheaper but the question is... can you put your cars power to the ground?
and i'm sorry did you just say that if you don't know a lot about cars then go turbo? was that a joke? no one should go turbo if they don't know what they are doing... "oh look i'm hitting more boost, its way faster!" then boom..
and i'd say to you with a good setup on a H22 for turbo the money spent could have a fast N/A H22.. I'd say for you to get a ride in a N/A honda thats got more than bolt ons and maybe you'd change your mind. another thing power means nothing.. its about putting the power to the ground.. turbo hondas spin like a bitch.. its what they do.. would you rather have something that spins its bitch off or something that hooks and goes? the choice is up to you but thats my opinion.. and jm991700 never say if you don't know how to do stuff to you car then go turbo.. thats one of the most stupid thing i've ever heard.HAN - ZiviCase10287
Honda-tech - zivicase
HMT - draztik
d-series - draztik
Team Integra - RacinMasonC
Originally posted by DraZtiKyour the prime example example why someone wouldn't go turbo.. i took my buddies for a ride and now they wanna go turbo.. everyone and their mom is going turbo in honda's these days just so they can produce power for cheaper but the question is... can you put your cars power to the ground?
Originally posted by jm991700First of all i type that wrong, i meant to say that if u dont know how to work on cars, i wouldnt put a turbo on a honda. And second u dont knwo what u talking about, A N/a wouldnt be faster then a good turbo setup turbo. A honda turbo N/a would never produce the same torque that a turbo can produce.IT just dont happen. And i dont understand putting a lot of money in a honda N/A to just produce maybe 40 to 50 hp.When u can spend the same money on a turbo setup and get a lot more hp and torque. I done a lot of research and took classes to know what to do to get what u want.
Comparison
B16A 1.74 liters
GSR 1.797 liters
B20 1.997 liters
Low boost torque
149 lbs
160 lbs
175 lbs
High boost torque
197 lbs
214 lbs
238 lbs
Which one will hook up the best; have the least amount of wheel spin and the best power band? Look at these charts… B16A flat out dominates. Undisputed. King. The thing is, nobody wants it. They all insist on building 2 liter turbo motors. And those motors are great in 3rd, 4th or 5th gear for sure, keeping up with bikes in some cases. But its going to get worked by any domestic V8 on any freeway onramp, and from any stop. Versus the B16A turbo I can actually launch very MEAN from a dead stop with less than 150 lbs of torque and when it hits 2nd gear, its going strong. I shift the GSR into second gear I get a big stripe on the floor, I shift the B20 into second gear and I hit the rev limiter from massive wheel spin (of course all of first gear was wheel spin too). Also, with a b16A motor you don’t get peak HP until very high in the RPM which is another advantage because you will be going a higher MPH when you hit the most power. AND you will have the least amount of torque! Versus a 2 liter where you will peak at about 7600 RPM or so, and have the most amount of torque. On that motor, you will have less MPH, more HP and more torque. Not a good combination. You want the tires to reach more MPH before more power touches the ground. It’s as simple as that. That’s why people buy longer gears for first gear, so they can get 10 more MPH out of first gear before they hit maximum power. This creates more traction. Ever wonder why all motor cars that weigh about the same just KILL turbo cars that have up to 300 horsepower more? Or even 50 HP more. Because the more horsepower, the less the car is going to hook, and the all motor car is GONE, with you catching up. Before you know it, you run out of track. And then you always hear the almost “guaranteed” excuse from the super high HP turbo guy. “I didn’t hook up, I was just spinning, and if I didn’t spin I would have killed you”. LOL that’s a laugh, when you hear that line just say “want to race again, double or nothing??” And kill him again, and again, and again. All day. What a joke! People actually expect their 400 wheel horsepower car to hook up and be neck and neck with all motor cars! And some cars I hear have 600 + WHP and want to race all motor cars for money. Can I borrow 10 grand to bet on the all motor car? No 600+ WHP cars or even 500+ WHP cars is going to hook for crap on the street without wheelie bars, and some HUGE slicks and $1000 dollar axles. On top of that, the more HP you have, the more skill and harder the car is to drive. So consistency is very, very difficult to achieve without the utmost practice and conditions. This is why the fast domestics go with power glide trannies. That is a 2 speed, automatic tranny. All they have to do is floor it and steer and they run fast, and consistent. If they had to shift gears 4 times like a Honda they would have a 20x harder time at it. Driving an all motor car that runs low 13’s compared to a turbo car that “can” run 11’s is like slow motion. I feel like I can sip a coke between shifts on the all motor car, while the turbo car is just: shift, bam, bam, bam, it’s over…very hard, or harder I should say.
GOT BOOST???
massive part out on accord almost everything is going
http://www.cb7tuner.com/vbb/showthread.php?t=125294
It sounds like all you care about are power numbers.
Those are worthless when you can't put it down on the ground.
A 250whp NA build will go down the 1320 faster than a 300whp turbo build would, both in the same chassis. (if both driven by drivers with identical driving abilities and both builds are built for the purpose of fastest acceleration down the track)
The turbo will have a higher trap speed tho.
Power numbers are for dyno queens and posers.
Originally posted by Dep22buildThis is an article from jeff at import builders
Comparison
B16A 1.74 liters
GSR 1.797 liters
B20 1.997 liters
Low boost torque
149 lbs
160 lbs
175 lbs
High boost torque
197 lbs
214 lbs
238 lbs
