is this motor obd1, obd2a, or obd2b
F22b1
help what do i need will a 90 f22a dizzy work and the tb work on this motor im sorry but i need to know what parts on a f series is swapable so i dont have to go out spending alot of money on newer parts and i can buy parts from an older f series at cheaper prices and i would not ask these questions if i did not do the search myself.
Why are you getting an F22B1 anyway?
If you must get that POS engine, get the OBD1 version. If you can only get the OBD2 version, use the parts from an OBD1 version (dizzy, ECU). I don't know for sure if the F22A parts will work... and the F22B1 is such a royal piece of crap that I never bothered learning.
umm thanks i think
actually i think hes s right and i have the engine. i spent way to much over the time learning about it.
just get the h22 and put the usuall bolt on and youll be much happier then the modifications required to put in the f22b1. or get a h23 and boost it.
id rather go with the h22 and get the usual bolt on if i had to redo it.
xLast edited by xfactortype1; 02-13-2008, 08:23 PM.
The F22a6 is pretty much better than the F22b1, another motor you can get local is a H23 like said above, F22a6-140HP F22b1-145HP H23a1-160HPOriginally posted by xfactortype1umm thanks i think
xwat?
