external coil
    external coil
    can u use the stock wires on an external coil setup or do u have to get aftermarket ones?
    im assuming you mean plug wires , it actually very easy to convert either way goto swap faqs in the swap section and you willl see I myself used a fuse on my JDM dist. because it was internal coil now im about to go external and the plug wires make no difference you just dont need a coil wire if u are going internal I didnt change my wires when i swapped ... hope this helps
    Fore Sale" My Ride "Best Time To Date 14.9 @ 94 MPH ...
      yes i do mean plug wires. and thanks
