soft clutch / not going into gears
    im having a tranny dilema...
    my clutch is all the way to the floor and sometimes when i shift it wont get into gear.. if i force it, it will grind n shit
    i just got a new clutch and flywheel..
    i stil think the clutch is good because it still catches the gear when it does shift...
    the fluid resevior seems pretty much full..
    do you think that the transmission needs to be bled? or what else should i do?
    bleading the clutch wont hurt for a start
      If bleeding doesn't work then either your master or slave cylinders are shot. Replace accordingly.
        either that or it can be you may need a clutch pedal adjustment aswell too in the mix.
