I have a P06 ECU, converted to P72 specs. That means I've added the IAB's and Vtec portions. That part works great with the regular basemaps but I have a problem with the datalogging portion.
I installed the CN2 Header and tried to data log the first time with a MAX233 chip install as a serial converter but NO luck at all, It worked one time and worked only to send and read what the chip had nothing else.
So I removed the max233 chip and bought a HULOG from xenocron, Installed it and still cant connect. I am using freelog. The latest version also.
The port settings are correct between the computer and the hulog.
All that comes up in free log is that Jonchi's code not fount. It fails the sanity test and dosent do anything else.
How do I fix this problem?
